Clutch help
Old May 29, 2008 | 06:12 AM
i<3myAP2's Avatar
Default Clutch help
I need some help finding what my problem is. I have a 2001 S2000 and my clutch pedal feels like sticky. More when pressed all the way to the floor.
Has anyone felt this before?
Any possible fixes?
Old May 29, 2008 | 08:55 AM
terahertz's Avatar
i fixed mine! i kept greasing the ball thing on the end of the slave cylinder, but it didnt do much. then i dislodged the clutch fork thing that holds the ball end and put grease on the other end with a flashlight and screwdriver. used honda hi temp urea grease since its gona be up in there with the clutch. dealer gave me a scoop for free
Old May 29, 2008 | 05:03 PM
tunermt's Avatar
possibly need to bleed the sytem if terahertz fix did not do it for you
Old May 29, 2008 | 09:02 PM
terahertz's Avatar
stickyness probably doesnt have anythign to do with teh fluid. bad fluid will make the top inch or more of travel mushy. but since you've got an 01, if you havent bled the clutch system in over a year, i'd do it. honda bled mine for me after i had a new master cylinder put in under warranty, but the fluid was slightly mushy after just 6 months. maybe i'm just anal, but i bled it and it felt great again.
Old May 29, 2008 | 09:39 PM
i<3myAP2's Avatar
Thank you i do need to bleed it. At how many miles was your master cylinder replaced?
Old May 29, 2008 | 10:37 PM
terahertz's Avatar
around 25k miles. premature failure i suppose
Old May 31, 2008 | 03:50 PM
HighwayStar's Avatar
i have the same and i have an 06 but do i have that ball thing on the end of the slave cylinder??
Old May 31, 2008 | 10:06 PM
terahertz's Avatar
the slave cylinder has a compressable side and on the end of that is a ball that fits into the cup on the clutch fork coming out from the transmission
g.guess88
Nov 7, 2012 09:07 AM
johnquester2000
34
Feb 20, 2012 10:43 AM
armanduhx3
Jacksonville
17
Aug 16, 2011 09:00 AM
G2k
Jan 2, 2009 07:58 PM
Turbo_tim
Jan 7, 2008 04:29 AM
