Serious Clutch Issues
Old Jan 4, 2008 | 07:18 AM
Turbo_tim's Avatar
Default Serious Clutch Issues
Hi fellas,
In desperate need of some help if possible. My friend was telling me about some trouble he was having with his clutch on his S2000.
The Problem
The pedal started to feel very loose and had a lot of play in it. The first half of the travel in the clutch pedal had no resistance behind it at all as if the hydraulic fluid was not being compressed. He managed to get it home where we discovered the master cylinder had a small leak in it. The fluid in the reservoir was also a little low so we presumed the seal in the master cylinder had gone and changed the whole unit. After filling and bleeding the system the problem is exactly the same . The clutch
Old Jan 4, 2008 | 05:38 PM
delorean696969's Avatar
More than likely your friends s2k has a broken tooth on the clutch. MY01 had the same issue, and like you I thought it was a hydraulic problem because I could pump the clutch a couple times and it would sometimes disengage.
Had the clutch, pilot, and throwout bearing replaced and solved the issue. Hope this helps man.
Old Jan 4, 2008 | 06:20 PM
BrandonS2K's Avatar
well i had the same problem mine would take alot strenght tot get it in first or reverse i just changed the fluid and nothing else and the problem went away. its been about 5 months not one problem. sounds like you may have somethin a little different tho
Old Jan 5, 2008 | 11:12 PM
jyeung528's Avatar
if you don't bleed properly...that could be an issue...
Old Jan 7, 2008 | 04:29 AM
TrackStar's Avatar
It's the slave cylinder or your bleeding technique. Replace the slave anyway as it will fee like a new car.
Jag528
Jan 24, 2012 03:21 PM
03S2
Feb 20, 2011 02:17 PM
OZshifter88
Sep 24, 2010 01:13 AM
DDuds2k
Nov 6, 2008 07:17 AM
epaplia
Oct 20, 2008 10:16 AM
