Clutch issue?
Old Jul 15, 2009 | 03:14 PM
spazbaboon's Avatar
Default Clutch issue?
About month or two ago my clutch went. I had it replaced by my mechanic. At first it drove excellent (since I was used to a poor clutch) then I noticed the pedal felt like it was sticking to the floor. After doing research and reading a bunch of threads, I figured I'd ask the mechanic if he bled the clutch. He didn't, which was wonderful news. So the clutch was bled and the hydrolics were cleaned. Still similar problem. Now it doesn't feel as sticky; it's fine when I drive the car the first time of the day, then after driving it it gets a little sticky and pretty stiff. My friend and I took off the slave cyl and felt that the cup thing and the fork were very dry, we threw some grease on it but probably not the right kind... Anyway I plan on buying the honda high temp grease and re-doing it this week. But could this be anything else? The mechanic said maybe the pressure plate but doesn't want to do anything about it ... I've put about 1k miles on the new clutch and have been pretty easy on it. Any other ideas? Should I shit bricks yet?
Old Jul 15, 2009 | 03:23 PM
spazbaboon's Avatar
Also every now and then, when I put the car in first immediately after starting the car, it will buck feeling like I'm randomly stomping on the clutch or gas.
Old Jul 15, 2009 | 03:34 PM
ahrmike's Avatar
sounds like your master cyl is on the way out. check for leaks under the dash to the piston/plunger thing attached to your clutch pedal. while youre at it, change the slave cyl as well unless your mechanic already did that. Also check to see if the guy adjusted your clutch master in the first place after changing the clutch - if he didnt, and someone earlier did adjust it to make up for the clutch wear, the master might not be opening the slave cyl enough to totally disengage the clutch.
Old Jul 15, 2009 | 09:04 PM
spazbaboon's Avatar
Ok thanks. I'll definitely look into that. Anybody else have any other ideas?
Old Jul 15, 2009 | 09:10 PM
Dougcsays's Avatar
Had the same thing happen got a new clutch in and it randomly would get stiff, they then replaced my slave my master and still its funky.... iv been driveing it since feb and it has gotten better but its still weird. Does ur clutch get realy lose when you hit vtech or drive it hard? Im actualy getting my clutch checked out by a different mechanic tommorow
Old Jul 16, 2009 | 10:03 AM
spazbaboon's Avatar
Good point dude. Yeah when I do get on it I stomp it because its usually stiff, but it disengages pretty easy, I guess like normal. It's so weird. Keep me posted.
Old Jul 19, 2009 | 08:36 PM
spazbaboon's Avatar
Also it feels like the clutch engages high when shifting gears. From stopped into first gear feels normal but when I ease my foot off the clutch while shifting in the upper gears it feels like it should engage much lower. Could anything in the hydraulics that needs to be adjusted?
S2kRally
Oct 20, 2009 03:44 AM
TimEdwards
Oct 1, 2008 03:54 PM
rikhemi
Jun 10, 2008 12:02 PM
thomas laporta
May 22, 2003 03:28 PM
Mans Best
Sep 13, 2001 05:47 PM
