Clutch Line replacement
Old Jun 6, 2015 | 03:56 PM
Reasonable Doubt's Avatar
Default Clutch Line replacement
So I was changing my MTF earlier today (first time btw, piece of cake thanks to this site )and realized my clutch line hose is cracking.
Not the clearest but i circled it. I read the stainless steel ones are the to go ones instead of the normal rubber ones, so which ones do you guys recommend ?
I plan to change my rear differential fluid next weekend so I can do the clutch line job at the same time since I'll have it up in the air.
Also what diff fluid is best recommended ?
Old Jun 6, 2015 | 06:24 PM
windhund116's Avatar
OEM rubber hose is fine. This line should not see the higher pressures seen in brake lines.
Old Jun 7, 2015 | 08:26 PM
Yea but won't it just eventually get worn out like the one that's on now ?
Aren't the SS ones supposed to be more reliable or last longer
Old Jun 7, 2015 | 09:42 PM
I don't think that damage in photo (though, it's hard to tell, 100%) --- is due to normal aging. It looks like someone or something may have damaged it, at one time. I guess it would not hurt to replace with a stainless steel line. PROVIDED it is well built and flexes are well as the OEM one.
Old Jun 8, 2015 | 04:43 AM
hmmm, ok. I'll try to get a better picture next time i have in the air. The SS ones are expensive tho and i couldn't find out the part number to OEM to compare the prices
Old Jun 8, 2015 | 05:54 AM
Number 12, in the link?
http://www.hondaautomotiveparts.com/...DER+%28+04-%29
Old Jun 8, 2015 | 07:52 AM
S2CK's Avatar
I have a SS clutch line installed on my car and I felt no difference from stock. As windhund posted, the clutch lint doesn't experience anything close to what the brake lines go through.
Old Jun 8, 2015 | 08:22 PM
jetboater's Avatar
As folks have stated, its not a high pressure line. The OEM one is $32 plus shipping on that link--or $47 at your local dealer.
For that price, I'd just go OEM.
Old Jun 9, 2015 | 06:51 AM
Thanks guys. Gonna go pick one up at the dealership.
Wasnt expecting a new feel. Just better life. If OEM last long might as well go that route and save money. If in the future i come across this issue again ill try the SS
Old Jun 10, 2015 | 03:15 AM
B serious's Avatar
The rubber line is durable. Unfortunately, some uninformed person might have pinched it with pliers to "save fluid" while swapping out a slave cylinder or something.
dominosguy
Sep 9, 2008 10:47 PM
IRev2NineK
May 26, 2008 06:00 PM
gary_phd
Dec 30, 2005 01:31 PM
MacGyver
Sep 5, 2005 09:50 PM
SilverstoneS2k_FL
Jan 12, 2005 08:18 AM
