clutch not engaging
i personally replaced the clutch master cylinder but took it to honda repair shop to replace the slave master cylinder....shifted fine for the first few miles, but then it started to stiffened when switching gears and now it won't go in gear at all while running. bled the system numerous times....any ideas on what it could be....faulty SMC??
cool...sure hope that is the case...I tried adjusting the cmc rod but still no luck...it seems like its that since the car won't start with the clutch pedal depressed...it will only lurch forward. taking it next week...easy fix means not alot of money....want to drop some cash on a set of xxr 526's!!
golfreak12
May 10, 2012 06:27 PM
donkeykong
Jan 11, 2007 11:59 AM
