clutch not engaging
Old Feb 7, 2013 | 11:01 PM
s2000afterlife's Avatar
Default clutch not engaging
i personally replaced the clutch master cylinder but took it to honda repair shop to replace the slave master cylinder....shifted fine for the first few miles, but then it started to stiffened when switching gears and now it won't go in gear at all while running. bled the system numerous times....any ideas on what it could be....faulty SMC??
Old Feb 8, 2013 | 11:48 AM
BEASTMODE's Avatar
Assuming the fluid is topped off and there are in fact no air bubbles...It sounds like the rod isnt engaging the clutch fork. Maybe the rod came loose or slipped off the fork somehow.
Old Feb 8, 2013 | 12:31 PM
jbee808's Avatar
This happened to me too.
We had to adjust the rod on CMC and then it was fine.
Old Feb 8, 2013 | 07:09 PM
cool...sure hope that is the case...I tried adjusting the cmc rod but still no luck...it seems like its that since the car won't start with the clutch pedal depressed...it will only lurch forward. taking it next week...easy fix means not alot of money....want to drop some cash on a set of xxr 526's!!
golfreak12
May 10, 2012 06:27 PM
03S2
Feb 20, 2011 02:17 PM
rikhemi
Sep 10, 2007 06:29 PM
donkeykong
Jan 11, 2007 11:59 AM
Big_Al
Nov 11, 2005 11:45 AM
