Clutch pedal depressing at high rpm in first gear
I looked around the threads but didnt see anything that helped so ill post here...
When at full throttle and high rpms (7-8500) in first gear, my clutch pedal draws in toward the floor board. When i go to press for shift i dont feel pressure until its almost at the floor and makes it a diffiult to get into 2nd gear. It only does this from first to second gear and at very high rpms. any suggestions?? The clutch was replaced w oem a few months ago and this hasnt been a problem until the last few weeks.
I as well have this issue it is in ANY gear, check all gears I have this same problem, i sometimes grind 2nd b/c of this because I don't have to throw the pedal in much when when it drops I have to and if I forget grind..
It is really Annoying. Have you done any fluid changes in the clutch system? Mine never use to do this until I installed a new clutch
Subscribed!
Subscribed!
No fluid changes since new OEM clutch was installed a few months ago. This wasnt a problem until just a few weeks ago so something has changed and i cant figure out whats causing it. Anyone with clutch experience/expertise care to help us figure this out?
I had this happen as well. It most likely happens with each gear change. No real reason it would impact one particular gear change.
With low RPMs the shifting was fine but higher RPMs my clutch pedal would have almost no pressure. Turns out the fork for the throw out bearing became disconnected from its pivot point and was rubbing on the trans case within the slave cylinder window. Without knowing this was the cause of my shifting woes I punched it hard one day and the fork locked the pressure plate to the disc and had to have her towed home for a new clutch and a new fork.
Lift the car and pull the slave cylinder and rubber boot that covers the window and see if the release fork is pivoting/moving properly.
^Good thought. Try the easiest thing first though -- check fluid, and add/bleed as necessary.
hshiznit Posted on Nov 11 2010, 02:43 AM
IMO this is because of an air bubble in the clutch hydraulics system.
Almost without a doubt.
But..
Combined with this:
I donno what rpm has to do with it.
It should have no influence.
twohoos Posted on Nov 11 2010, 09:25 PM
And check the master & slave for leaks.
Fresh fluid will stop the leaks, that's been reported by many.
Jspd Posted on Nov 11 2010, 06:46 PM
I guess a bad throwout / unlubed fork finger can cause this.
When a throwout goes bad, you get load where its not supposed to be.
As soon as a bad throwout starts pulling the spinning PP back, you get a load on the stationairy part of the throwout, the groove where the fork fingers are in = "torque" on the fork and its pivot point.
Even more if those fingers have no lube on them.
But..
Combined with this:
pwr2al4
07-14-2015 09:21 PM
crisskro
11-12-2013 06:46 AM
