Clutch pedal noise
Old Nov 12, 2006 | 07:32 PM
melonheadr6's Avatar
Default Clutch pedal noise
Hey all,
I've searched the forums but could not find an answer to my problem.
My clutch pedal is making a weird creaking sound. I initially felt it and heard it while I was driving. When I got home and turned off the engine, the creak/squeak is still present.
The sound appears as I am lifting my foot off the pedal. It does not make the sound on the way down. Only on the way up. I can actually feel the squeak in the pedal. At first my roommate thought it was a master/slave cylinder issue. But after crawling under the car, we could not localize the sound.
I found a possible TSB for it: "SN040203 02/01/2004 Clutch Pedal Is Noisy or Feels Notchy"
In my case, it feels notchy and is noisy... I am no longer under warranty. Does someone have the full details of the TSB? Just in case I can fix it myself at home.
Thanks!
Old Nov 12, 2006 | 07:55 PM
FISH22's Avatar
it may be the slave cylinder. this is notorious for making this noise/feel. i've also had this, along with a loud click in the pedal on my old ap1. but after a few thousand miles, it ended up going away. give it some time.
Old Nov 12, 2006 | 07:58 PM
Spec_Ops2087's Avatar
I have the same squeak noise only when letting off the clutch but never felt anything different.
I think its normal.
Old Nov 12, 2006 | 08:49 PM
kane.s2k's Avatar
Just grease up the shaft under the hood.
Old Nov 12, 2006 | 09:16 PM
Kane,
Could you be more specific? This is my first manual car... I'm not very savvy. Thanks for the help!
Old Nov 13, 2006 | 10:07 AM
SpitfireS's Avatar
Have a read here:
https://www.s2ki.com/forums/index.php?showt...hl=clutch+pedal
Doing that solved it for me.
It does take some tools to do this fix at home.
But it could be the pedal pivot points itself, the slave, the master or the (brake = clutch) fluid or a combination of the four too.
Old Nov 13, 2006 | 12:17 PM
Originally Posted by SpitfireS,Nov 13 2006, 11:07 AM
Have a read here:
you are THE man! thanks a ton!
Shaney
Aug 8, 2014 11:19 AM
StatixNWH
Aug 13, 2012 03:17 PM
AZDavid
Aug 22, 2006 02:10 PM
daltb84
Nov 27, 2003 07:06 AM
Bang2nd
Jul 28, 2002 04:19 PM
