Clutch? Transmission? Syncros? Help!
Old Nov 23, 2010 | 08:48 AM
s2000maniac's Avatar
Originally Posted by BlackBearTX,Nov 23 2010, 08:49 AM
Update: Tranmission shop said the Master Cylinder is leaking fluid and needs to be replaced. Getting it done tomorrow.
dont replace the master cylinder....just change the fluid. the leak will stop. your wasting $$$
Old Nov 23, 2010 | 08:05 PM
BlackBearTX's Avatar
I actually decided to cancel it since it was gonna be $500 and when they replaced the fluid and got the air out... my clutch hasn't been this smooth even the day I bought it almost 2 years ago now (come December). So I might have had this problem for the past 2 years.
I can't tell if you're joking the leak will stop D:.
Do you guys think there will be a major problem down the road if I don't fix this problem? I backed out of it, I will carry brake fluid in my trunk and see if the problem occurs again within 6 months or if the fluid seems to be leaking.
How hard would it be for me to install a master cylinder myself, it seems like several people mess with this component on the AP2 to delete the CDV from the clutch slave cylinder.
http://www.hondaautomotiveparts.com/auto/j...NDER+%28+04-%29
My quote was $505, if I remember correctly on the phone the master cylinder was to be $160 and the slave $130.
On that site the slave and master is $138.43, if I couldn't do it myself reliably, I could probably pay the well repped local guy to install it, and save $200.
The transmission guy said he just wanted to go ahead and replace the slave with the master, that nothing was wrong with it -_-.
Old Nov 23, 2010 | 08:52 PM
ahrmike's Avatar
get both the mnaster and slave and get it installed somewhere else. 500 bucks? you gotta be kidding me! it was like 200 for the parts, and I did it myself in less than a coupe hours (both master and slave).
Old Nov 24, 2010 | 10:02 AM
Why did you end up having to replace yours? Similar issue?
Rio Sunset
Mar 6, 2015 03:21 PM
s200000
Nov 28, 2013 10:17 PM
stwoki
Feb 24, 2011 07:15 AM
CR22
Sep 16, 2009 10:48 PM
jstar
Jan 6, 2007 05:27 AM
