code 0116
Old Dec 5, 2007 | 07:41 PM
Slows2k's Avatar
If the cooling system hasn't been opened recently the only source for the air is a external or internal leak.
Blown Headgaskets can leak coolant into the bores and you get the same disappearing coolant symptoms as a external leak.
Old Dec 5, 2007 | 07:42 PM
Wael El-Dasher's Avatar
but wouldn't I smell it in the exhaust?
Old Dec 5, 2007 | 07:46 PM
Slows2k's Avatar
Usually, but not always. Especially if you catch it early. I've worked on quite a few 91-95 Legends that wouldn't smoke out the exhaust or smell and had both headgaskets blown.
Old Dec 5, 2007 | 07:53 PM
I do want to add that this evening (its about 27F outside) while idling to read the code, the temp gauge was at 4 bars. I have never, ever seen it at 4 bars. I suspect it's an air pocket in the system. The radiator fans didn't turn on and the large coolant hoses didn't feel hot, they were just a bit warm, but that's it.
Thanks again
W
Old Dec 6, 2007 | 03:28 PM
I paid attention today to my parking spot at work and noticed the area under the reservoir has coolant on the asphalt. So this leads me to believe the overflow tank is spilling out coolant. I suppose that may mean the thermostat is not opening.
Any other ideas?
Thanks
W
Old Dec 6, 2007 | 05:20 PM
Slows2k's Avatar
Blown HG pushing coolant out of the reservoir, or it's overheating and pushing coolant out of the reservoir.
ry4nolson
Jan 19, 2012 07:54 PM
r_duff
Dec 14, 2009 02:07 AM
r_duff
36
Oct 31, 2009 03:46 AM
EriS2k
Feb 11, 2005 10:17 PM
