Cold Air Intake Or Hot Air Intake???
Old 03-21-2004, 03:58 PM
project x's Avatar
Default Cold Air Intake Or Hot Air Intake???
ok i got this cai but after some studies found out it really needed a heat shield so i went down to the home depot and...... before
after Home Depot..... do yall think this will do a good enough job???
Old 03-21-2004, 04:00 PM
BenR's Avatar
It really wont do anything.
Radiated heat isnt really an issue with air temps, and thats not sealing any of the filter element from average underbonnet temps.
Old 03-21-2004, 04:59 PM
xviper's Avatar
A lot of hot air comes over the rad and through the rad.
I'm also a little confused about how the air that comes from the pipe before the filter gets filtered.
Old 03-21-2004, 05:04 PM
paivag's Avatar
Wouldn't that CAI benefit from one of those hoods with cut outs??? I never seen that setup before. What is it?
Old 03-21-2004, 05:06 PM
ninegrand's Avatar
I'm with xviper...
Does that filter go straight through? And what brand is this?
Old 03-21-2004, 05:31 PM
BenR's Avatar
i'm assuming there is a conical filter in the mouth, so its not unfiltered.
Old 03-21-2004, 06:20 PM
PilotKD's Avatar
It's and RM Racing intake. Looks cool, but it's $350. Even if that heat shield does nothing, you did a pretty good job on it and it looks cool.
Kris
Old 03-21-2004, 06:55 PM
project x's Avatar
this is correct, the filter is concave on both sides of the pipes, with a large filter in the center, it is RM Racing as well!
Old 03-21-2004, 06:57 PM
project x's Avatar
oh, and the heat shield is a bit higher than the rad........
Old 03-21-2004, 06:58 PM
hygiene boy's Avatar
On this intake there is pleated gauze on the front of the filter between the secondary tube and the filter. The secondary tube is just for a slight ram air setup as there is a scoop that sits in the grill connected to corrugated tubing and then it goes up to the secondary aluminum tube . It's essentially a very expensive short ram intake . The RM racing website says it's on sale for $475? WTF?
Quick Reply: Cold Air Intake Or Hot Air Intake???
