Cold Engine Rev Limiting
Old Mar 19, 2002 | 07:31 AM
Alz2002's Avatar
Default Cold Engine Rev Limiting
Does the ECU limit revs BELOW 9K rpm when the engine is cold? I seem to remember a dealer saying something like that, but forgot about it until I tried to VTEC right out of the parking lot at work the other day.
Thanks for the info.
Old Mar 19, 2002 | 07:45 AM
Sideways's Avatar
It is fun to put your face on the windshield first thing in the morning! Enjoy your new car but let it warm up first.
Three bars on the temp or the fuel cuts off.
Old Mar 19, 2002 | 09:04 AM
Psicho54's Avatar
When you're sleepy in the morning, nothing works better at waking you up than hitting the limiter ...
How could I describe it ... the feeling of hitting a brick wall.
Old Mar 19, 2002 | 10:35 AM
chrts's Avatar
try dumping the clutch w/ only one bar of temp.
chris
Old Mar 19, 2002 | 11:21 AM
Alz2002's Avatar
Yep, that's the one. It's an especially keen feeling when you are sort of leaning forward anticipating VTEC. Good thing it's soft leather on the steering wheel.
Old Mar 19, 2002 | 11:29 AM
coop's Avatar
it is limited to about 7000 rpms
Old Mar 19, 2002 | 11:48 AM
CoralDoc's Avatar
Please be kind to your engine. Until the engine is properly warmed up (usually 5-10 minutes after 3 bars first show up), you can place a lot of wear on the internal parts.
Old Mar 19, 2002 | 05:29 PM
tbalon's Avatar
Actually I have heard conflicting stories. my 2001 rev limits at 9,000 regardless of temperature however the vtec will not kick in until the car is at three bars. I have heard that some 2000 cars rev limit at 6000 when cold. Need to search the manual.
Old Mar 20, 2002 | 06:12 AM
Alz2002's Avatar
My seatbelt tensioner tells me the '02 is rev limited. I do baby my engine most of the time, especially when cold, buy, hey, VTEC happens. The ECU probably sensed that I punched it because I was coming up on a Mustang Cobra, and it knew better.
Old Mar 20, 2002 | 03:09 PM
Utah S2K's Avatar
Utah's Tech Tip of the Day:
The car doesn't give a damn if you have 2-3 or 4 bars. V-TEC solenoid relates to oil pressure. The viscosity of Honda oil hits the majic number at about 3 bars.........
Utah
ONEQUIKSTI
May 30, 2006 10:27 AM
Dragon Curve
Oct 15, 2004 04:39 AM
hyun83
Aug 20, 2003 03:50 PM
san2000
May 21, 2003 02:43 AM
zero_to60
Jan 17, 2003 04:26 PM
