COLD START PROBLEMS!
its normal, all s2k's in cold weather have this problem. I found that cranking it once or twice for a split sec, but not starting it, then starting it. that makes a difference. But a thinner oil will also help.
Originally Posted by dimi,Dec 16 2008, 03:37 PM
It's normal. Some say its the ECU, some say its the little bit of fuel frozen in the pump which cannot prime on the first go. Happens to me too.
Originally Posted by FASTSIIK,Dec 16 2008, 08:31 PM
its not frozen fuel. Gas does not even begin to freeze til -97 degrees F. its possible ths ECU is part of the problem becuase it can't compensate for cold spark plugs. There isn't one thing that makes this problem but more a combination of things. But the main problems are how cold temps effect oil and batteries. Cold temps make oil thicker and batteries weaker. So thick cold oil and a battery in a weakend state make a hard start. So a battery with a higher CCA will help alot.
