Compression Check Numbers
Old Mar 22, 2007 | 12:18 PM
Raines48's Avatar
Default Compression Check Numbers
Well I figured I would test my car this past weekend while helping out a friend on his car. I have a tester and never used on my s2000. Are these numbers okay? I tried a search but couldn't find any other numbers...
Test was done with a warm engine.
1-230psi
2-240psi
3-240psi
4-245+psi
#4 was weird it kept wanting to go up on the gauge when cranking the car. #1 wouldn't go up anymore then 230 no matter how many times I cranked it. Should I be worried?
I have about 34,000 miles on my MY03 but still have the extended warranty. Should I take it in for the low #1 cylinder? Any input appreciated.
Old Mar 24, 2007 | 06:28 AM
gotswap's Avatar
As long as they are within 15% of each other you are of. #'s look good!
When you say #4 kept wanting to go up was 245 the highest #? Did you have the throttle open when cranking?
Afterglow
May 20, 2012 11:50 AM
BEASTMODE
Oct 19, 2011 09:01 PM
762
Nov 19, 2010 04:51 PM
Xherrox
Mar 21, 2009 04:56 PM
jert534
Jul 18, 2006 06:38 PM
