heavy fuel smell
Old Mar 23, 2007 | 07:40 AM
BAMbam160's Avatar
Default heavy fuel smell
In the last few days I've been getting a heavy fuel smell inside the car. I did a search on the other forum and the closest topic was after a SC install. The car has 50k on it so I couldn't imagine the injector o-rings are leaking. I checked the fuel lines running from the tank to the engine bay. Nothing looked to be leaking, loose, or dripping fuel. I only smell it in the cabin, once your outside the theirs nothing. I checked the seal inside the fuel cap and it was good. Anybody else have similar issues? Could it be the charcoal canister? Thanks for the help.
Old Mar 23, 2007 | 08:06 AM
cdelena's Avatar
Usual cause is a missing oil cap.
Old Mar 23, 2007 | 11:07 AM
Saki GT's Avatar
Did you just top off the fuel tank? If so, when you fuel up, do you keep pumping gas into the tank after the initial kick off by the pump?
Old Mar 23, 2007 | 11:20 AM
BAMbam160's Avatar
oil cap is straight. I thought it was just due to over filling of the tank but, I've had that tank for a week and its nearly on "E" and I'm still getting the smell
Old Mar 23, 2007 | 11:53 AM
Saki GT's Avatar
But how did you fill your tank? Even if the main tank is empty, fuel can be in the fume filter if you overfilled, and it will just have to evaporate.
Old Mar 23, 2007 | 12:28 PM
plokivos's Avatar
spray all the carpets with some febreeze and see if the smell goes away. If not, you might want to see the seals on the head, and take the rear carpet out on the trunk to see the actual fuel pipe to see if there are any leak.
Old Mar 23, 2007 | 05:57 PM
milkbubble's Avatar
Maybee you can check under the soft top where the spare tire is stored. You can see all the fuel neck and related goodies in there.
Old Mar 23, 2007 | 06:00 PM
S~Factor's Avatar
Fuel line leak in the engine bay... this one drove me crazy for 3 years!
Old Mar 24, 2007 | 06:41 AM
John_Z's Avatar
Since you recently installed an SC I would say it could be:
-loose fuel delivery/return line at the pump
-loose fuel lines on the fmu
-torn top injector o-ring
-bad seal between the fpr and fuel rail
Stoatmaster
Jun 13, 2012 05:55 AM
TonysMI4
Aug 28, 2011 11:21 AM
siadam
Apr 25, 2009 06:53 PM
Reaper 6A
Jul 15, 2007 07:04 PM
