Compression Test
Old Feb 19, 2004 | 03:04 PM
heffergm's Avatar
I'm going to be adjusting my valves this weekend, so I figured I might as well take the time to check compression on all 4 cylinders.
Does anyone happen to know what the compression specs are? Although I'll be watching more for even compression across all 4 cylinders, I'm also (obviously) interested that they're still within spec.
Thanks!
Old Feb 19, 2004 | 08:39 PM
Venomous S's Avatar
Nominal = 228psi
Minimum= 135 psi
Variation = 28psi
In my car I got 210 all across, just make sure to hook up a battery charger so you get constant cranking...
Old Mar 18, 2006 | 02:14 PM
iam7head's Avatar
Originally Posted by HardtuTame,Feb 19 2004, 09:39 PM
Nominal = 228psi
Minimum= 135 psi
Variation = 28psi
Nominal = 228psi
Minimum= 135 psi
Variation = 28psi
that's a 7 crank or 5 crank? i suppose this is the same for ap2 and ap1 right?
Old Mar 18, 2006 | 04:31 PM
REVZ TO9's Avatar
Banned
so what if I lost some compression? What caused it and how do I fix it? Ive never checked this before. Can this all be checked when I get my 45,000 mile service done soon?
Old Mar 18, 2006 | 04:52 PM
Wisconsin S2k's Avatar
honestly, there is no reason for you to get this done ztopgun. a compression and leakdown are usually done when you suspect a possible bent valve or leak somewhere in the cydliner, generally causing a misfire and a CEL.
there's no reason for you to "get this done" when you have your 45,000 mile service. in fact, as long as the car is running properly, there's no reason to do it at all. FYI the dealership would probably charge you at least $150 just to do it. don't waste your money ztopgun.
he's just doing it since he's getting a valve adjustment and wants to double check the car.
Old Mar 18, 2006 | 06:36 PM
REVZ TO9's Avatar
Banned
ok gottcha
Old Mar 18, 2006 | 07:47 PM
camuman's Avatar
150 bucks!!!!! holy shiznit. damn, dude, come to my place and i will do it for a nominal fee of 75 bucks.....thats half off
go buy the gauge, its easy to do.
Old Mar 18, 2006 | 07:49 PM
Vladimir L's Avatar
I had 235 on most of my cylinders.
dsddcd
Feb 20, 2019 03:31 AM
jdblood202
Aug 9, 2014 06:43 PM
GomezWvC
Jun 22, 2013 09:33 AM
thatsahonda
Mar 26, 2009 04:14 PM
Moddiction
Jun 20, 2008 08:53 AM
