compression test
Old Dec 30, 2005 | 12:01 PM
f20c1 01s2k's Avatar
Default compression test
has anyone done a compression test on their s2k?? if so..please list your car year and each slot you've tested. i wanna see what are the numbers out there..also..does anyone know what the numbers are suppose to be?? anything would help thanks.
Old Dec 30, 2005 | 04:35 PM
CrazyPhuD's Avatar
Numbers don't matter much consistency does...you want all the numbers close to each other.
Old Dec 30, 2005 | 04:42 PM
kayvan_pour's Avatar
Banned
Some what true... If they are all at 150 thats a bad sign, so consinticy isnt always the best. But usually is good!!
Sup minh! Make sure when you do the test the motor is warm or you will get wierd numbers. As far as the numbers go, I would say anything above 200-210 is good, being around the 240-250 range would be the best.
Old Dec 30, 2005 | 05:24 PM
jimknapp's Avatar
Spec is 225 PSI. But that depends on a few things:
1. the engine must be warm.
2. the gauge itself must have as short a hose as possible, or at least a really tiny diameter. If you get these long "convenient length" gauges, where the gauge sits on the fender while you spin the motor, you'll never get your number because the volume of the hose adds to the volume of your combustion chamber. Of course the best bet is a gauge with a Schrader Valve (that's a tire valve) in the nose is the best because they will just keep filling the long hose bit by bit.
And yes consistency IS what you want, but high consistent numbers is mo' bettuh'.
Ciao,
Jim
Old Dec 30, 2005 | 05:58 PM
Slows2k's Avatar
Jim's got it
Old Dec 30, 2005 | 07:33 PM
thanks guys..ill check my compression in a few days..
Old Dec 31, 2005 | 01:55 AM
XXX240's Avatar
My JDM reads 260psi on all cylinders.
Old Dec 31, 2005 | 09:28 AM
jimknapp's Avatar
Hey Slow...
Find me a used F22C will ya? I'm trying for some records in the next class up, 2 liter to 3 liter and my F20C will do them easily, but it doesn't have enough cubic inches to "qualify" for the class.
Later,
Jim
Old Dec 31, 2005 | 11:26 AM
Slows2k's Avatar
I may have a line on something you can use Jim. I'll PM you when I've got more info.
Old Dec 31, 2005 | 05:45 PM
jimknapp's Avatar
Kewl, Slow...
And thanks,
Jim
darkvette07
Jul 1, 2017 05:01 PM
turbodreamz22
May 10, 2013 12:02 PM
Moddiction
Jun 20, 2008 08:53 AM
SpaZilla
May 4, 2006 01:04 PM
mxt_77
Jul 19, 2004 08:26 PM
