Compression test and plugs
Old Dec 6, 2008 | 11:17 PM
k24accord's Avatar
Originally Posted by SgtB,Dec 6 2008, 11:30 AM
You only put oil if you get a low number. If it reads higher with oil you have a worn ring.
correct. thats usualy a good way to figure out if a piston ring is worn out.
also, remember that consistency between cylinders is more important than the actual number. the actual number will vary on the amount of times you crank the motor, etc. anything over 20psi between cylinders and you have a problem
Old Dec 7, 2008 | 07:44 AM
SgtB's Avatar
Originally Posted by BeachBum17,Dec 6 2008, 09:17 PM
thats what ive heard. Also i heard you don't need to give it throttle
You absolutely have to open the throttle, otherwise the engine is trying to suck air through a straw and will give false readings.
Old Dec 7, 2008 | 01:19 PM
A.J's Avatar
A.J
Banned
with a 3mm headgasket i was at 195 across the board
Old Dec 7, 2008 | 06:05 PM
RedY2KS2k's Avatar
Since you've heard these things, why did you ask for help on this forum. Just go ahead and do what you've heard and let it go at that.
Old Dec 7, 2008 | 06:50 PM
BeachBumS2K's Avatar
way to be a dick about things
Old Dec 7, 2008 | 07:10 PM
RedY2KS2k's Avatar
You deserved it.
Old Dec 8, 2008 | 06:00 AM
CosmosMpower's Avatar
I just did my compression test Sat. Warmed up the car and drove it around town for about 15 mins. Came back pulled all the plugs immediately and started the test. Cranked each cylinder 7-8 times and came back with 212 exactly across all 4 cylinders. Oh yeah I did not hold the gas down while I did it. 160 seems low.
Old Dec 8, 2008 | 02:12 PM
wow 212? hmm thats a big difference. I think im going to test it two more times when i get the chance, once with no throttle and the next time wot. You have an 06 so the motor should be the same, i wonder if mileage has anything to do with the numbers i have 69 thousand and my clutch is deffinitely on its way out, but that shouldn't effect compression obviously.
Old Dec 9, 2008 | 07:08 AM
I have a MY00 S2000 with 122K miles on it. My 06 is my Lotus Elise.
Chr1s7ian
Oct 14, 2018 06:53 AM
lopez14
Nov 8, 2013 09:48 AM
jshimer23
Jun 17, 2008 04:55 AM
Sargeant Handbag
Mar 4, 2008 12:45 PM
HondaS
Jun 12, 2007 02:11 AM
