Converting AP2 drive by cable to drive by wire
Old Jul 2, 2017 | 07:35 AM
tot's Avatar
tot
Default Converting AP2 drive by cable to drive by wire
My '06 DBW engine took a crap and I bought an '05 drive by cable engine as a replacement. The '05 engine is in and I've swapped out the trigger wheels, intake manifold, and valve cover. I started it up and it sounded like I had an exhaust leak. It turns out that I didn't account for the hole left from not having a secondary air valve.
What's the best way to get an '06 DBW intake manifold to work on an '05 drive by cable head? It seems like this channel for the secondary air valve is my last hurdle, but I may be overlooking more.
Is it just a matter of plugging up this hole?
Here's a photo of the '05 intake manifold next to the installed '06. My thumb is next to a secondary air valve bolt and my pointer is showing the blank space in the '06 cars where that bolt would go.
Old Jul 2, 2017 | 08:14 AM
tot's Avatar
tot
I dug around some more and I think I may have found a solution here https://www.s2ki.com/forums/s2000-fo...plates-811525/
Originally Posted by neeman77
I just used a short extension on a deep socket, no universal joint required. The best way of eliminating this system is tapping the EGR holes on the exhaust side of the head after removing the metal cover and then putting in set screws with JB weld on them. This is what I did when I did not have an 06+ head.
Old Jul 2, 2017 | 09:07 AM
flanders's Avatar
Might be easier to drill and tap the air valve and ad a block off plate.
weenrock
Mar 14, 2019 05:06 AM
ennjoi
Dec 3, 2009 02:41 PM
ash2k
Nov 17, 2008 02:27 PM
Grendel
Mar 8, 2008 07:25 AM
Creed5150
Jan 1, 2007 05:38 PM
