Coolant flush - block drain sealant, non-Honda coolant
Old 08-31-2011, 02:32 PM
oldtrlrnr's Avatar
Default Coolant flush - block drain sealant, non-Honda coolant
I'm getting ready to do my first coolant flush on my stock 04 AP2. Just reviewed the procedure in the shop manual and DIY procedure on threads in this forum. Couple of questions:
1. If I do open the block drain bolt, as opposed to draining the block at the oil cooler hose, is it OK to use Permatex blue RTV silicone gasket maker, which I have, or should I get the HondaBond liquid gasket stuff?
2. I have several gallons of Prestone extended life coolant, labeled as GM Dex-Cool approved, intended for 5-yr duty, labeled as silicate-free, phosphate-free. Is this stuff OK for our engines, or should I get the Honda Type II blue coolant?
Appreciate advice.
Bob
Old 08-31-2011, 02:40 PM
s2000maniac's Avatar
DO NOT use anything other than Honda OEM coolant fluid. But hey you dont have to listen to me .....
Old 08-31-2011, 05:49 PM
zeroptzero's Avatar
Received 3,387 Likes on 2,458 Posts
If you can get the block drain bolt open you are a much better person than me, that thing was a major pain in the butt. I never opened it yet I got pretty much all of the fluid out of it.
Permatex sealants are good, they u sed to have a grey one that was very similar to hondabond.
I only prefer Honda coolant, looking at my rad that was seven years old it was totally free of any deposits or corrosion running Honda coolant , It looked brand new. I wouldnt use anything else regardless of price.
Old 08-31-2011, 06:01 PM
FSTFWRD's Avatar
Dex-Cool is only good for killing weeds. I wouldn't put it in anything I own. Total crap.
Old 09-01-2011, 01:36 PM
oldtrlrnr's Avatar
OK, heading over to my local Honda dealer to pick up a couple of gallons of the Honda Type II coolant - $19.95/gal (sigh).
Guess I'll use the oil cooler coolant line to drain the block.
I put the Prestone extd-life coolant in my 2003 Pilot last summer - hope it's OK.
) Bob
Old 09-01-2011, 07:35 PM
oldtrlrnr's Avatar
Well I'm done. I picked up 4 gal of Honda Type 2 coolant at local dealer; did the flush/fill. Seemed like I only got ~ 5 liters out, but it took at least 6.5 liters to fill . I didn't even attempt the block drain bolt; struggled with the oil filter cooler line until I decided to remove the air cleaner box to improve access. But when I got that hose off, very little coolant came out. Oh well, it's done - and I did an oil & filter change while I had it up on the jack stands. Car is ready for my 2600-mile trip to Montana (from Los Angeles westside) to visit friends.
S2000Matt
08-26-2010 12:25 PM
AlyWW
07-19-2009 04:14 AM
pgss2k
05-17-2009 04:40 AM
pputkowski
10-20-2008 11:31 AM
Tyraid2K
08-31-2007 06:50 AM
Quick Reply: Coolant flush - block drain sealant, non-Honda coolant
