Coolant leaking from over flow tank.
Me too.
The coolant overflow tank cap has a rubber gasket washer on the underside, the gasket should be tight up to the underside of the cap, and the hose pushes up tight against the washer so it all sits tightly together to help reduce potential leakage.
Originally Posted by boyguan
i havent added coolant ever really.
if the hose was clogged would the explain the smell?
Bumping an old thread. I went to the track yesterday and I think I have a similar problem. I never any problems prior to this. Coolant sprayed everywhere on the right side of my engine bay. It looked like it was spraying out of the overflow tank cap. My engine temps appeared fine during my sessions, but I was definitely losing coolant after each session. I tried screwing the cap on tighter, but it didn't seem to make much difference.
Did changing your cap fix your problem? I've replaced my cap once before when it cracked. My current cap doesn't look like it has any damage to it. I'm thinking about just replacing the whole assembly including hoses.
