coolant valve?
Old 10-21-2008, 12:09 PM
drhess06259's Avatar
Default coolant valve?
does anyone know what the valve looking thing on the firewall above the headers is called? I know it has coolant running through it, but not sure what it does, any help is appreciated.
Old 10-21-2008, 12:13 PM
krikke_s2000's Avatar
it's the valve that adjusts the amount off water
running tru the heater in the car
grtz kristof
Old 10-21-2008, 12:17 PM
can it be moved? or is it really needed? can i just put a new coolant line in with no valve?
Old 10-21-2008, 12:29 PM
without the valve the heater in the car will always be on the highest temp
grtz kristof
Old 10-21-2008, 12:41 PM
krikke thanks for the help. i could deal with that as long as it doesn't affect the ac controls also, like blow hot and cold air when running the ac, I don't drive the car in winter anyways, so I rarely use the heat as it is.
Old 10-21-2008, 12:43 PM
if you remove the valve the heater is always going to blow hot even with ac on
grtz kristof
Old 10-21-2008, 01:04 PM
ahh that is no good.. thanks again for all the help
Old 10-21-2008, 02:18 PM
thetz99's Avatar
That's a coolant air purge high point. You need it to purge ALL the air from the coolant system when you do a flush...if your heater doesn't get hot, you didn't get all the air out.
Has nothing to do with controlling the heater temp btw, lots of bad info above.
Old 10-21-2008, 02:27 PM
the coolant air purge high point is above the engine in the midle of the car the heater controle valve is above the header
grtz kristof
Old 10-21-2008, 03:17 PM
Slows2k's Avatar
Bad info has been posted by you as well.
The valve does control coolant flow to the heater core. Air in the cooling system will cause overheating, and no heater /defrost operation.
Coolant flow to the heater core is shut off by the valve for AC operation.
Quick Reply: coolant valve?
