Creaking while breaking
Old Aug 15, 2014 | 03:44 AM
mikey430's Avatar
Default Creaking while breaking
Hey guys so for about a few weeks now I've noticed that a creaking noise starts to happen when I'm coming to full stop, but the noise only happens at low speeds right before I completely stop. the noise starts around 10-15 mph when slowing down and continues until i make a full stop or let off the brake pedal. The front brake pads were changed earlier this year around March/April and i also had the rotors resurfaced at the same time. My car is my daily driver and never sees any track action/autoX. Once in a blue moon i'll take her for a canyon run, but nothing crazy. Most recently I bled the brake fluid using the gravity method about 2weeks ago since the fluid looked like coffee >.<
Everything has been replaced with oem parts: the pads, brake fluid and the resurfaced rotors are oem. Not sure if that enough info, but any and all advice will be appreciated. My S is '00 w/ aprox. 83K on the clock.
Old Aug 15, 2014 | 05:09 AM
Reckon's Avatar
What about your rear brakes? Have those been looked at? Also, have you done the axle nut torque?
Old Aug 15, 2014 | 07:52 AM
slalom44's Avatar
Top Answer: 1
Check your caliper bolts. The ones that bolt the caliper to the knuckle. If you didn't torque them enough or if the threads get dirty and prevent a complete torque you will get a squeak at low speeds.
I had to use a hand tap to clean one of mine up. I use anti-sieze compound and apparently some grit got on the threads making it hard to torque down, causing a squeak. After running an M-10 x 1.25mm tap through the threads on the knuckle the bolt went in easily.
Old Aug 15, 2014 | 08:46 AM
Gregg Lee's Avatar
"Creaking while breaking" Don't most things creak as they are breaking.
Old Aug 15, 2014 | 10:07 AM
Car Analogy's Avatar
For those less than entirely literate, breaking and braking are two very different things.
ES2K
Jan 16, 2012 07:51 PM
tre3478
Mar 5, 2010 04:08 AM
VitaRenovatio
Aug 8, 2008 10:46 AM
Itr#249-rip
Dec 26, 2006 03:33 PM
bigpurp
Jul 21, 2004 05:58 PM
