Cutting dash for gauges
Over this upcoming weekend, I'll be cutting out the dash for gauges with a hole saw. I've looked in the helms manuel and there is apparently a wire harness going across the dash. Problem is, each picture in the manuel shows the wires in a different location.
Where is this wire harness really located? If its somewhere close to the front, I'll take extra precaution not to cut it as I'm sure that wouldn't be good.
Thanks
Thanks
Originally Posted by RunUrAss,Mar 8 2007, 02:06 PM
i dont know about the wires but if you cut holes in your dash for the gauges...where's the tv going to fit in?
j/k...are you going to wtd?
Originally Posted by vtec9,Mar 8 2007, 03:02 PM
don't do it!! Dash cutters club is a cult.. don't drink the koolaid. stick the gauges in the radio door.. unless they're really deep
Anyone know where the harness in the dash is?
There is nothing DIRECTLY behind the dash. So cut but dont keep going once you're through. Keep in mind that the dash is held in place by a couple of plastic brackets though so you might hit that but no biggie.
Do your self a favor. Remove the passenger's air bag first. Then you can see behind where you are cutting too. There is a harness back there. In fact there is two behind the dash. Both of them cross the dash completely. They cost well over 800 to replace them both, so if you are cheap (I assume you are because you are DIY, as would I) so look before you cut.
SideWaysOnFire
Jun 6, 2008 02:11 PM
