CV joint help
Old Aug 5, 2008 | 03:47 PM
Ilike2DRIFT's Avatar
Default CV joint help
I had a vibration under acceleration, so i figured it was the drivers side cv joint. sure enough it was!
My question is do i buy a new one or just swap it?
It's definately worn to the point were u can see it. Also i was playing with the grease and could feel alot of metal shavings in it...
Is it worth buying the spacers?
Finally if i drove on it to long is it possible i damaged anything else, like the shafts?
Thanks for your help!
Old Aug 5, 2008 | 05:19 PM
negcamber's Avatar
Unlikely your half shafts were damaged. And since you've already got the CVs out...just swap them. No need for spacers.
Old Aug 5, 2008 | 06:02 PM
oops! i forgot to mention i'm lowered on H&R springs.
63K on the odometer.
Old Aug 6, 2008 | 06:45 AM
jshimer23's Avatar
From the pictures it's obvious you already have at least one out. At this point just swap them. Buy some Redline CV-2 grease, repack them and swap them. The vibrations should be gone for quite some time.
When they eventually come back, but the 2 piece spacers and once again, you'll be vibration free for quite some time again.
Old Aug 6, 2008 | 10:34 AM
thanks for your opinoins. I baught the Redline CV-2 grease and will be swapping them today.
Is there any specific way to pack the grease in, or a certain amount i should use?
Old Aug 6, 2008 | 10:44 AM
SpitfireS's Avatar
Ilike2DRIFT Posted on Aug 6 2008, 08:34 PM
Specific way: fill them from the bottom (flange side) and the sides.
Certian amount: 5.3-5.6 oz.
I would work some into the little bearings as well IF you washed them out.
Old Aug 6, 2008 | 01:52 PM
jshimer23's Avatar
I bought the grease in a tube (I think 14oz). I sqeezed in a little less then half for each "bucket" and used some to lube up the bearings. I had a little bit too much in the one so when i "burped" the boot, a bit popped out.
Old Aug 7, 2008 | 08:48 AM
Thanks again for your help guys!
Overall it took me about 4 hours to do.
I swapped the cv joints and replaced the fluid with reline.
Next project is adjusting valves
DDAP2S2K
Dec 31, 2011 05:59 AM
tua40278
Jan 9, 2011 01:04 PM
houstonpv
Aug 3, 2010 04:25 PM
Neuman04
May 24, 2010 08:13 PM
JimmyB
Jul 11, 2008 06:42 PM
