dash light stay daylight mode and no runign lights
The other day I got in my car started it and turned my lights on headlight came on just fine but the dash stayed as if the were off any suggestions?
Details
My00
One headlight other ones balist blew and I removed it
Happened shortly after sub woofer Install
Details
My00
Not sure if this is also connected to your issue.....My gas gauge is dim even if the headlights are off. When I turn on the headlights, everything goes dim and the gas gauge is darker than the rest.....Are they connected to this thread's issue?
Someone pointed out my taillights are also out so I'm thing fuse or relay brake lights and headlight still work thow and if I turn my high beams on it dosnt show on gauges
dealership will charge you $96 and up just to see if they can point the problem out. this is a electrical issue not mechanical. i recommand you go to a Audio and Video shop, they specialize in electronics and they should be able to fix it for $50 or even less.
