Dead battery!
Old May 9, 2009 | 08:43 AM
Jamie_Murray's Avatar
Default Dead battery!
The battery has needed to be replaced for about 6 months, but since I don't drive the S right now there's no point in spending money on a new battery.
Tonight is a special occasion and I decided to drive the S2000, but now the car won't start.
It's just me and I can't get the darn thing to bump start, so my question is this.
Can I take the battery out of my 2000 Toyota Celica and put it in the 2001 S2k and it work?
I haven't looked up the specifications on each battery and I'm highly doubting this will work, but hey.....who knows, maybe I'll get lucky.
Old May 9, 2009 | 11:29 AM
negcamber's Avatar
12v is 12v. The Toyota battery should have enough cold cranking amps to start an s2k. Only question is if it will fit in the s2k battery box.
A buddy was able to pick up a perfectly fitting replacement s2k battery at Wal-Mart of all places.
Old May 9, 2009 | 11:31 AM
Bob A (SD)'s Avatar
Bets are it was an Everstart 51-4/435CCA which is a great choice for the S2000 available at Wally World Put one in my MY03 last year.
Old May 9, 2009 | 01:36 PM
iam7head's Avatar
yep, as long as the CCA is the same or better yet: higher then you'll have no problem getting started
my sister's GTS' battery is 550cca, i believe our stock is around 500
Old May 9, 2009 | 01:54 PM
Bob A (SD)'s Avatar
Originally Posted by iam7head,May 9 2009, 03:36 PM
i believe our stock is around 500 cca
Actually, at least for the AP1, the stock battery is Group Size 51R, 12V-36AH/5 hours 410CCA which is why that WallyWorld Everstart 435CCA isn't such a bad way to go given their warranty and availability and all.....
Old May 10, 2009 | 03:52 AM
clag's Avatar
Same here, no issues. I understand there are many brands but few actual manufacturers when it come to batts, so I went cheap. I actually found quite a few testimonials in favor of the Wal-Mart brand on the fishing sites. Those guys work the hell out of batteries with their trolling motors. Good luck.
Old May 10, 2009 | 02:18 PM
iam7head's Avatar
you might very well be right.
i reason i said it might be 500cca is that the interstate replacement i am rocking is 500cca, group size 51
the stock panasonic lasted me about 3 years with a decent sound system and couple deep discharge, which is not bad.
Old May 10, 2009 | 02:20 PM
iam7head's Avatar
another option to go cheap is to get reconditioned battery, i got my interstate recon battery out the door for 25 buck(all size, extra for optmia)
the last interstate recon battery lasted 5 years and counting, i am on my second one for my s(after panasonic took a dump)
Old May 10, 2009 | 03:55 PM
SquirtleS2K's Avatar
Walmart or autoparts store is fine for a battery. look for a warranty because most batteries are made out of recycled old batteries unless otherwise noted.
s2kcanuck
Apr 22, 2015 06:44 AM
spakko
Jul 1, 2007 05:10 PM
hornyhonda
Sep 1, 2006 04:52 AM
lvs2k
Feb 12, 2003 11:27 AM
seung
Oct 2, 2002 06:21 PM
