dead speedo anyone?
Old Dec 12, 2005 | 07:21 PM
hk20000's Avatar
Default dead speedo anyone?
hey guys anyone had experience of the speedo/tripo all crap out on you at once? My speedo stopped working today so I don't know wtf is going on.
check engine light came on too but the car drives just the same....
lemme know what are your experiences...
Old Dec 12, 2005 | 08:30 PM
xviper's Avatar
Your car is trying to tell you something. Pull the code and find out what it is.
Old Dec 13, 2005 | 10:02 AM
xxjdxx's Avatar
i had my hole cluster go out last year. My car also was running fine, if your still under warranty dealer should fix it with out any questions.....
Old Dec 13, 2005 | 11:41 AM
hk20000's Avatar
yeah dealer ran the scanner and told me the speed sensor is dead....at first
then they went under there and wiggled it a bit and it worked again, and then check engine light also went off...
weeeeird I thought only Germans have bad electronics... I guess it's not bad if it's not officially broken.
Old Dec 13, 2005 | 11:55 AM
xviper's Avatar
That area is exposed to road grime and moisture. Upon inspection, you'll see that the wire insulation and outer wrapping is not very good. It might be wise to use some electrical tape to better seal it up.
Old Dec 13, 2005 | 04:14 PM
Tugz_S2K's Avatar
Banned
That code would be transmission speed sensor
Old Dec 13, 2005 | 04:15 PM
Tugz_S2K's Avatar
Banned
Sounds like a soft set coupler to the speed sensor on the transmission....Dealer just unhooked the coupler, wiggled the sensor then properly set the coupler....code goes away
Old Dec 13, 2005 | 04:19 PM
cntcu's Avatar
mine reads but it reads way too high, and it only started happening after i replaced the clutch...anyone else have this?
Old Dec 13, 2005 | 07:07 PM
xviper's Avatar
Are you sure somebody didn't sneak in a set of "gears" while they were doing the clutch?
ayS
Jun 14, 2007 11:11 AM
an_orange_s2k
21
Mar 11, 2007 01:47 AM
sweetj
May 16, 2003 10:29 AM
SilverSurfer
Oct 23, 2001 04:05 PM
notstr8
Sep 26, 2001 05:04 PM
