Deceleration noise on 07?
Old Jan 13, 2009 | 01:34 PM
hexum311's Avatar
Default Deceleration noise on 07?
Hello all. I have read the numerous threads posted about the clutch buzz TSB. My queston is this, should this still be common on an 07 model?
I am not sure if the sound in coming from the exhaust or the engine. Its hard to tell, but if defintely only happens upon deceleration between 3-4k and goes away whey the gas or clutch pedals are pressed in.
I havent had a chance to get under the rear yet to see if anything is loose. But its been going on as far as I can remember. I bough the car new with 10 miles on it. It now has around 8k. If its not common I guess I will take in to honda, but I would have thought this problem was fixed by 07. Does anyone know this for sure?
Thanks
Old Jan 13, 2009 | 02:58 PM
negcamber's Avatar
Clutch buzz should not be a problem on the 07...
Old Jan 13, 2009 | 03:28 PM
vincewchan's Avatar
My buddy has an 05 and the car has clutch buzz.
Old Jan 13, 2009 | 03:42 PM
Slows2k's Avatar
Unless the car has an Aftermarket clutch, you don't have the same noise.
Old Jan 13, 2009 | 03:56 PM
hexum311's Avatar
No aftermarket anything. Its all stock.
Weird thing is its the exact same symptoms. It sounds more from the rear and exhaust.
I guess I was hoping someone would reply back and say ... I have an 07 too and its the exhaust heat shield, tighten the two bolts by ... lol
I had great luck with the tips on this forum about the top ticking noise on drivers side in cold weather. Found a thread that pointed out the exact spot and it was right on. I guess I was hoping to get lucky twice.
Old Jan 13, 2009 | 03:57 PM
Slows2k's Avatar
It's not the clutch buzz.
Old Jan 13, 2009 | 05:34 PM
shotgunjimmy's Avatar
that sounds exactly like the clutch buzz in my MY01, except mine doenst sound like its coming from the rear.
Old Jan 30, 2009 | 07:51 PM
walkercart's Avatar
any news on this, i have an 08 with 6k and i have the same problem. Might take it in, next week
c32b
Jun 22, 2009 02:56 PM
gearshifter
San Diego S2000 Owners
Sep 5, 2008 08:56 PM
s2000zr
Jul 3, 2007 07:31 AM
J.nguyen
May 25, 2007 12:22 PM
Bandit_287
Mar 27, 2007 04:40 AM
