Denso Iridium and engine missing
Old Nov 4, 2001 | 06:38 AM
pfb's Avatar
pfb
Here is a photo from an old post about installing a pro-flow throttle body...
Old Nov 4, 2001 | 06:56 AM
captainnice's Avatar
Thanks for the pic! That helps!
Old Nov 4, 2001 | 09:09 PM
S2KALI's Avatar
I have recently experienced the same problem some infequence--momentary fuel cutoff at high rpm. Since I know very little about mechanical subjects, please allow me to ask further questions in detail.
What tools do I need to remove the MAP sensor?
What do I use to tap the MAP sensor?
How hard do I tap the MAP sensor?
What does tapping do to "fix" the sensor?
If it's faulty, why shouldn't I just take it into the dealer for a replacement?
Thanks!
Old Nov 4, 2001 | 09:25 PM
pfb's Avatar
pfb
The MAP sensor is very easy to get to and can be removed in a few seconds. It's held on by two phillips head screws.
It is a pressure transducer. It "converts manifold absolute pressure into electrical signals to the ecm". There is a picture of the internal workings of the device on page 11-22 of the service manual.
I can't imagine why tapping on it would help, but from my old stuck carburetter float days, a quick rap with the handle side of the same #2 phillips screwdriver you would use for removal is the "standard mechanics tap"
Frankenstiein_B20
Feb 4, 2010 04:24 AM
Saki GT
Feb 5, 2008 08:28 PM
cthree
Nov 10, 2004 06:26 AM
chroot
Oct 23, 2002 12:54 PM
slowpokes2000
Jul 13, 2001 02:15 PM
