Did compression test, but forgot one thing!
Old Jan 9, 2012 | 05:42 AM
2002 S2000's Avatar
Default Did compression test, but forgot one thing!
I did it correctly with the exception of one thing. I forgot to go WOT. Should I redo it? With no throttle, the numbers were 149-151. I just put in new plugs to so I would rather keep them in place since they have crush washers, I believe.
Old Jan 9, 2012 | 07:43 AM
jh4db536's Avatar
With no throttle I did 230 across the board. 150 sounds pretty low?
Sent from my T-Mobile G2 using Tapatalk
Old Jan 9, 2012 | 08:13 AM
starchland's Avatar
your looking for variation between the numbers, as long as they were all done with the throttle closed I would do it again, and that way you can kinda compare better to what others are geting (even though every gauge can read differently)
Old Jan 9, 2012 | 08:25 AM
skoundrel's Avatar
Its completely fine to unthread the plugs and re-install them. I would do the test again.
Old Jan 9, 2012 | 10:17 AM
2002 S2000's Avatar
Did it with fully warm, WOT for about 8 seconds each cylinder and still got about 150 (+/- 1 psi) across the board. The compression tester is brand new, but I'm going to see if Advance or Auto Zone has one I can borrow to see if the it's the tester. I just bought the car, so it makes me nervous. Seems to drive just fine with the 6,100 rpm VTEC kicking in.
I'm going to cancel my aftermarket warranty (refundable upto 60 days) if the compression, UOA on the diff and tranny fluid are all good.
Old Jan 9, 2012 | 10:21 AM
spectacle's Avatar
That's pretty impossible.
Old Jan 9, 2012 | 12:38 PM
2002 S2000's Avatar
I figured out the issue. The straight extender part that came with it must be bad. So, I used just the long hose and gauge and they are were at 238-241. That's a relief!
Old Jan 9, 2012 | 12:41 PM
jh4db536's Avatar
Tell that to alex at ballade
Op: Great to hear your numbers are good
Old Jan 10, 2012 | 09:48 PM
turbo_slug's Avatar
No it's not. Mine actually did 240 without throttle wot.
Backmarker
Feb 19, 2016 05:27 AM
Aydon
Oct 22, 2013 03:07 AM
s2kneub
Apr 30, 2013 11:25 PM
jshimer23
Jun 17, 2008 04:55 AM
