Dif leaking?
Old May 12, 2010 | 12:14 PM
AIm2kil's Avatar
Default Dif leaking?
Hey guys I just noticed today that my car seems to be leaking dif fluid. How would I stop this? I am going to change the fluid soon anyways (next two days) should I worry about it untill then. The leak is very slow, 2-3 drops a day.
Thanks
Old May 12, 2010 | 12:18 PM
SUPERAnimal's Avatar
That would be your differential mount leaking. Those mounts are fluid filled. You're probably gonna want to replace both mounts.
Old May 12, 2010 | 03:51 PM
AIm2kil's Avatar
What would this cost me to fix, myself and at a dealership. Looks like the parts are cheap, but I think I would have to remove my exhaust. How long will it be ok to drive with this?
Old May 12, 2010 | 03:55 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
All you need to drop is the sway bar, and the mount will come out.
Left leaking mount is a common problem. Just change the leaking one. Fix it yourself, it is very easy.
You're ok to drive a little while. you wont harm anything.
Old May 12, 2010 | 03:57 PM
Billman250's Avatar
Top Answer: 1
I'm going to add...only fix it yourself if you are 100% confident in your ability to safely raise the car to work on it.
Old May 12, 2010 | 04:14 PM
AIm2kil's Avatar
I am, change my and am under cars very often. Thanks for the help guys.
AstroPhsx
Dec 12, 2009 08:02 PM
Artesial
Mar 17, 2009 09:10 PM
dan_uk
Feb 10, 2009 04:47 PM
rehgee
San Diego S2000 Owners
May 17, 2008 09:34 AM
Siepel
Jul 4, 2005 04:30 PM
