Diff or Axel blown?
Old Dec 12, 2012 | 02:44 PM
  #21
S2SEXY's Avatar
same problem as the op,so im pretty sure the trans is still in one piece .im going to order a axle and let you know after i replace it.
Old Dec 12, 2012 | 03:43 PM
  #22
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
you can order a inner CV kit right from honda. comes with new bucket, spider (part thats broken), rollers, boot, and grease.
Old Dec 12, 2012 | 05:53 PM
  #23
johngamez's Avatar
Originally Posted by S2SEXY
this thread was very useful.i just had the same thing happen to my car.i didnt think it could be the rear/axel since i had the car towed/pulled and while steering it home the rear didnt make any noise.the boot for the cv joint on the left side is indeed twisted.
Ballade Sports has a heavy duty cv joint assembly that will address and fix your issue. The cv joint assembly they sell at Ballade Sports is an updated and improved product over the standard Honda OEM unit. The housing is a ONE piece design with a modified bearing track for reduced friction. The STD factory unit is originally a 2 piece design with an inertial weld. The internals of this product use the same style tripod roller bearing assembly as STD Honda, but features high performance needle bearings within each roller, unlike the STD Honda bearing. This unit is proven to last longer and reduce friction rotation than the OEM unit. The housing is larger in overall diameter increasing strength and uses HTS2 high temperature axle grease. Basically, the kit is equipped with everything needed to install. I highly recommend you look into this product if you are considering replacing your cv joint soon. The standard Honda unit is simply not as reliable as this assembly.
Here's the link to the website:
http://www.balladesports.com/product...t-assembly-kit
There are pictures for you to compare the OEM Honda unit and the Heavy Duty CV Joint Assembly Kit
Give Alex a call and ask him any questions you have regarding the product. He's always ready to genuinely help anyone out. I have gone to him for all my s2000 inquiries and products and can truly say that he does great and honest work. He's a very cool guy so don't be afraid to call him up.
Old Feb 24, 2013 | 03:42 PM
  #24
s2k-fc3s's Avatar
wow this is very helpful!!!!!!!! i just bought a ap1 today but it doesnt roll when i put it in gear and it makes the same sound that the op posted in the video...it almost sound like the splines are grinding..am hopeing its a twisted boot will check tomarrow..thanks for useful info billman 250
dripking07
Sep 1, 2010 07:02 AM
DP's-s2k
Jan 24, 2009 06:44 AM
mwy23
Jul 20, 2005 06:39 AM
mwy23
Jul 19, 2005 09:50 PM
elemental79
Nov 20, 2004 09:26 PM
