Diff fluid change
Originally Posted by mikegarrison,Aug 27 2008, 03:14 PM
Just so we're clear on the original question:
You're imagining it.
Originally Posted by SpitfireS,Aug 26 2008, 02:39 AM
The Torsen LSD uses friction to "lock".
Old oil may have lost its EP (Extreme Pressure) capabilities making the Torsen behave differently, especially coming out of corners under power.
This I have experienced myself, sudden understeer on small roundabouts.
It felt like the inner rear wheel pushed the car forwards in stead of around the corner.
As if it was locked too much with the outer rear wheel (making more revs)
At first I figured I had a steering rack problem or one tire with low pressure.
Nope.
Fresh oil (SAE 90 GL-5) "fixed" it completely.
The old oil came out black AND was pretty thin (cold!) compared to what went in.
Nope.
You can use water, grape jelly, air or diff fluid. It will still lock just the same. Negating the need for lubrication, ofcourse.
The diff ONLY uses the oil for lubrication.
B serious Posted on Aug 29 2008, 08:29 PM
Yeah..... sure.
Worm gear by themselfs don't lock or do anything.
One typical thing worm gears do have is that they produce axial forces when they transfer power (torque)
Why don't you put air in your diff and show us how well it still locks?
Ohh.. wait... you need lubrication too?
So lets see... it will work with air but you still need to lubricate....?
No it doesn't. It uses a worm gear.
CrAzYNeSs
Nov 15, 2004 08:47 AM
Destiny2002
Feb 9, 2004 12:41 PM
thereisnospoon
May 16, 2003 07:47 PM
