Diff Fluid quesion
Redline Oil makes two different types of 75w90. one is made for limited slip. and one says. "not for use in limited slip differentials", one has the friction modifier addditive and one does not. which fluid do i get. being S2K's do NOT have clutch type LSD's? should i get the one with the FM's just to be safe? is it ok to put FM's in the AP1 differential? I'm ordering fluid in 2 days. please respond. Thanks
per REDLINE 75W90 is correct. I asked their 'tech' dept.
BTW, I switched both the MT (MTL) and the diff (75W90) a couple of weeks ago (about 500 miles). the shifting is like butter, a lot less clunk and the 2-3 shift is much better.
the one i used on my other car is 75w90 weight, which is not recommend for s
