Diff Fluid quesion
Old Jun 27, 2007 | 08:34 PM
fit4897's Avatar
Default Diff Fluid quesion
Redline Oil makes two different types of 75w90. one is made for limited slip. and one says. "not for use in limited slip differentials", one has the friction modifier addditive and one does not. which fluid do i get. being S2K's do NOT have clutch type LSD's? should i get the one with the FM's just to be safe? is it ok to put FM's in the AP1 differential? I'm ordering fluid in 2 days. please respond. Thanks
Old Jun 27, 2007 | 08:38 PM
Stratocaster's Avatar
You don't need any friction modifier or addditives. 75w90. GL4 will be just fine.
Old Jun 28, 2007 | 02:34 AM
CoralDoc's Avatar
No Friction Modifier is necessary since our Torsen differential is gear-based and does not use friction plates.
Old Jun 28, 2007 | 03:40 AM
CKit's Avatar
Has to be GL4, though.
Old Jun 28, 2007 | 03:52 AM
SpitfireS's Avatar
The official diff oil recommendation is SAE 90, GL-5 (/GL-6).
No multiweights, no GL-4 rated oil.
Check your owners manual to confirm.
Old Jun 28, 2007 | 04:05 AM
bluemeanie's Avatar
per REDLINE 75W90 is correct. I asked their 'tech' dept.
BTW, I switched both the MT (MTL) and the diff (75W90) a couple of weeks ago (about 500 miles). the shifting is like butter, a lot less clunk and the 2-3 shift is much better.
Old Jun 29, 2007 | 12:46 PM
iam7head's Avatar
what weight is the redline mtf?
the one i used on my other car is 75w90 weight, which is not recommend for s
Old Jun 29, 2007 | 01:54 PM
S2kracka's Avatar
I believe the MTL is a 75W-80, eitherway, the MTL matches the Honda spec exactly.
Use the regular Redline 75W-90 GL-5 in the rear diff.
littlealex
Apr 3, 2010 11:18 PM
niahuynh
Sep 9, 2008 07:39 AM
lukas2k
Nov 29, 2007 05:29 PM
F20_C
Jul 10, 2005 03:37 PM
SaV
Nov 11, 2001 08:14 PM
