Diff oil weight recommendation? 2018
Finding lots of GL5 hypoid gear oils as well as notes going back to at least 2002 that GL6 spec is obsolete in that GL5 does everything it did.
Amsoil has a flexible "Easy Pouch Bag" GL5 in 75W-90 and 75W-140 grades. Looks handier than those messy little pumps needed for the rigid bottles. 75W-110 which may be the most appropriate only comes in rigid bottles.
The data sheet for LE-1605 I just downloaded shows it as a GL5 oil, but the sheet is dated 09-14. Also rated as MIL-L-210SE. Looking for a more recent sheet at present. Royal Purple, Red Line and others, of course have GL5 lubricants so we're back to the inevitable What's best?" question.
-- Chuck
-- Chuck
Reading both parts puts this in good perspective. Higher grade reduces friction and consequently reduces the limited slip function of the differential by a, perhaps, insignificant factor. Torsen's "house oil" is Chevron Supreme LS 80W90. Yep, a LS oil.
Extract from the API website (emphasis added)::With the Honda spec being GL-5 or GL-6 the GL-5 is certainly good enough.
-- Chuck
-- Chuck
I've sent an email to Torsen.com trademark holders of the torsen diff about preferred fluid. I got quite a surprising answer.
"The short answer is it doesn't make much difference to the differential."
Full answer:
"With regards to you lubrication question - the short answer is it doesn't make much difference to the differential. Ultimately, it’s a question for the axle manufacturer. What I mean is, the differential operates as just one component in a larger system, a system that shares lubricant. The axle assembly that contains the differential also contains other significant components to which proper lubrication is equally (or more) important. Helical gear differentials like the Torsen that came in your car can actually operate in wide range of fluids and are not particularly fussy about it, so long as the lubricant is of a good quality. They will operate just fine in all of the oil weights that you've mentioned. On the other hand, the ring gear and the pinion gear that drives it are extremely fussy about correct lubrication. So are the bearings and oil seals, though most people don't consider them.
A lot of people ask the same basic question - what lube does the Torsen need? Basically, I have to point out that this is not the correct question to ask, for the reasons mentioned before. What you need to ask is "what oil does my ring & pinion gearing need?" That is what you should be concerned with, as the differential itself doesn't really care. You'll need to ask the gear manufacturer that. If you are using the production ring & pinion gears, that information should be included in your owner's manual, or available from the dealer."
Full answer:
i have used many different fluids in the past including 75w90 mobil 1, amsoil 75w140 and LE1605.. granted i dont track my car its only street driven after having blackstone labs do a UOA le1605 came back with the lowest wear metals.
there is also someone on here that has tested different fluids as well and have noted le1605 showed cooler differential temperatures as well compared to others. run whatever your heart desires,
All that data is with the "old" LE-1605, not the current lubricant which is no longer marketed as meeting GL-5 standards. This change occurred recently. New bottles and all. If you get a test of the current lubricant please share it.
I'm still on the fence but have several more months before a change is scheduled.
-- Chuck
-- Chuck
