differential blown~!
Old Jan 21, 2011 | 05:36 AM
  #61
S2KPUDDYDAD's Avatar
Originally Posted by 00CivicSi,Jan 21 2011, 09:07 AM
S2KPUDDYDAD and SpitfireS,
Thank you both for your wealth of information. I did have an additional question...
How often would you recommend changing the differential fluid for regular street use? How about for low mileage cars (garage queens); would you recommend based on time rather than mileage?
Thanks,
Chris
Thank you
I would do a change once a year for diff fluid. It is cheap and not hard to do
Old Jan 21, 2011 | 05:40 AM
  #62
JPRICE!'s Avatar
you have another option that i just finished up last night...kia 4.77 gears. Im about to do a write up on it so check for the thread.
Old Jan 21, 2011 | 10:55 PM
  #63
SpitfireS's Avatar
Gear oil does not get contaminated by combustion byproducts like engine oil (acidid stuff etc) so if you don't drive a lot you could go 2 years IMO.
OTOH, like S2KPUDDYDAD said: its cheap & easy to do, so.. it doesn't hurt.
I would not use the OEM milage oil change interval - a little too long.
Both for the trans and diff.
Personally I change diff & trans every 25-30k km, about half the OEM interval.
Old Sep 14, 2016 | 08:57 AM
  #64
alanleun's Avatar
Originally Posted by S2KPUDDYDAD
Originally Posted by boxmetogo,Jan 9 2011, 02:42 PM
That DIY is just for the R&R not changing out the broke internals of your damaged rear.
I built the replacement rear for that DIY
With trade of you old damaged rear I send you a reconditioned rear ready to go for less than you can rebild your self.
I also helped shock with that build as well
If you chose to rebuild your self you can call me for instructions or advice. Good luck
Puddy how much do you charge for a refurbished differential with the exchange of a broken one? Im new to the forum and cannot seem to PM you.
HondaGuy714
Oct 19, 2014 04:31 PM
slowsilvers2k
Feb 24, 2011 07:37 AM
westmobs2k
Mar 1, 2009 06:44 PM
s2k_PikeStyle
Oct 30, 2006 03:51 AM
ls2k
May 6, 2006 06:28 PM
