Differential Problem
Old Jan 30, 2008 | 11:41 PM
dwedge's Avatar
Default Differential Problem
My car was Vortech super charged a few months ago,
and I'm starting to hear click noise from the rear end.
I'm guessing somewhere in the rear end is broken.
How can i solve this problem? i think a oem diff will cause the same problem after a while.
Who sells reinforced differentials??
Old Jan 31, 2008 | 04:35 AM
S2KPUDDYDAD's Avatar
It may not be your diff at all, sounds like axle nuts or a wheel bearing. Have the car looked at first before spending money on something you don't need
If you do end up needing to replace the rear diff, you do have a few choices
HTG
Or InLinePro
My self
We can all be found here on this sight, good luck
Old Jan 31, 2008 | 04:38 AM
Lil Kriss's Avatar
Hey i have the same thing, when im takin off in forst and when i shift down, any idea what it is?
Old Jan 31, 2008 | 04:49 AM
Please read the above advice or do a search on axle nut/wheel bearing symptoms.
Old Jan 31, 2008 | 12:43 PM
nightcrawler7188's Avatar
if you don't feel a difference and it's just a sound, it's most likely the common axle nut pop.
Old Jan 31, 2008 | 05:10 PM
HondaS's Avatar
if its a constant clicking than its the same problem i have and im pretty sure its the CV joints. i plan on relplacing the axles and wheel bearings while im at it pretty soon
Old Feb 1, 2008 | 05:41 AM
Moddiction's Avatar
Former Sponsor
Does it make a single click when starting out in first gear? I have a single click noise which I believe is the axle nut needing to be re torqued.
Old Feb 1, 2008 | 06:23 AM
nibble's Avatar
it's axle nut and bucket issue. not diff. if it was diff, car would've not move.
Liam701
Oct 17, 2017 02:05 AM
-Jordan-
Jan 23, 2011 08:50 PM
Vtecfool
May 7, 2009 09:28 AM
GRM
Apr 7, 2009 01:39 AM
cloud_9
Dec 17, 2007 10:20 AM
