Dim Headlight
Old Sep 19, 2009 | 11:19 AM
ssthrd's Avatar
Default Dim Headlight
I have my bumper off and the passenger's side headlight out to check that the parts are correct, and they are. They are identical on both sides.
The light is not so dim that it doesn't look normal to the layman, but when I checked it with a light meter (I can't remember the numbers) it was quite a few hundreds of lumens lower than the other side. It's hard to see up the right side of the road.......
I found the problem just after I got the car while adjusting the headlights. I covered up the left side with a towel so I could better see where the cutoff lines were, and found that the right line was not only different (curved upward like the inside of a bowl), but also dimmer,
Anyone have any ideas? I tried a search, but found nothing specific to this problem. Do Ballasts "wear out"? Could the projector be faulty?
I posted here before and got no answer and a search doesn't provide an answer. If anyone does have an answer, I'd like to hear it. I don't feel like forking out big bucks for a little fix.
Old Sep 19, 2009 | 02:37 PM
Fast Jack's Avatar
Back in the day,a dim head light meant loose ground wire.Should be in the vicinity near by.
Old Sep 20, 2009 | 10:15 AM
ssthrd's Avatar
Found the problem. For whatever reason, the wire clip that holds the bulb in place was bent wrong, and the bulb was big time crooked. It must have affected the focal point of the unit (??).
No matter, It's fixed. I can now actually see down the shoulder of the road. For the longest time i thought my lights sucked, but now they are awesome. I threw a set of PIAA's in for high beam, and I'm good to go.
Thanks for the advice ttang.
Old Sep 26, 2009 | 07:01 AM
ssthrd's Avatar
Sorry Fast Jack. Didn't mean to leave you out. Thanks for your advice.
I had a plastic car "back in the day", and it cost me 1500 bucks to have a shop tighten a ground strap. Turns out it wasn't the case here thank the gods.
Anyway, the fix was quick and cheap.
A warning to others--don't force the clips into place. If you have to do that, something's wrong.........
Fizoust
Jan 12, 2010 09:54 AM
keemaca
Oct 22, 2009 11:06 PM
ssthrd
Sep 20, 2009 10:20 AM
f23power
Jul 13, 2008 01:54 AM
rev29k
Aug 13, 2002 07:41 PM
