Disabling the A/C compressor for autocrossing?
Old May 28, 2003 | 10:19 AM
Gernby's Avatar
Former Sponsor
Default Disabling the A/C compressor for autocrossing?
I would like to be able to turn the A/C on during an autocross just to have the cooling fans run continuously, but don't want the A/C to engage. Is there a quick, simple way to do this by pulling a fuse or unplugging a harness? I have considered just swapping out my accessories belt before / after the event to bypass the A/C compressor all together, but thought it might be bad for the compressor clutch to stay engaged the whole time.
Old May 28, 2003 | 10:21 AM
Gernby's Avatar
Former Sponsor
Come to think of it, would it do the same thing to just short the radiator fan switch?
Old May 28, 2003 | 04:32 PM
xviper's Avatar
I think it would very easy to "hot wire" both fans to switches. Tap power via relays (unless you can get big enough switches) from your battery and splice into the fans. Have the switches in the cockpit.
Old May 28, 2003 | 04:58 PM
Gernby's Avatar
Former Sponsor
I am hoping to avoid cutting and splicing. I tried that on my old Integra, but found that 1 was switched on the +12V side, and the other was switched on the GND side. I rigged this big mess of relays and switches, but it didn't last.
Old May 28, 2003 | 05:13 PM
Slows2k's Avatar
You could try unplugging the AC clutch connector, Both fans should run with the AC switch on
Old May 29, 2003 | 02:36 AM
jguerdat's Avatar
I suppose someone could protest you for that. Pretty chickenshit but possible. I try to NEVER add electrical load during a run to minimize engine drag. I'll use the A/C, if needed, during grid but will shut it down and will switch the heater control to full heat. Can be a bit uncomfortable but the shot of cooler water and extra radiator capacity may be worth it.
Taylorman93
Aug 6, 2017 12:16 PM
p0staboy
May 13, 2011 03:42 PM
Spec_Ops2087
Jun 16, 2010 06:04 PM
Bass
Jun 14, 2008 04:29 PM
ccarnel
Apr 17, 2003 10:56 AM
