disturbing find today/motor ready to blow
#31
Originally Posted by yogi,Sep 21 2004, 04:53 PM
They are different parts:
'00 - '03: 14765-PCX-000
'04 - '05: 14765-PRB-A01
#33
Originally Posted by yogi,Sep 21 2004, 09:33 PM
Now if we can drag 'ol Woodwork in here to explain (if he knows) the difference between the old part and the new one...
#35
Woodwork sent me this pic with the following explanation:
"The valve end is still in the split retainer. Too much force on to close
the valve without the rocker pushing on the other end of the valve."
#36
Originally Posted by billman250,Sep 19 2004, 09:17 PM
Idle is smooth...no noise....As long as Honda doesn't need the car asap for warr. service, I'm going in with a borescope to ck the valve head and piston, and doing a compression and leakdown test. David1, I'll get some nice pics for ya Anybody know where we can check retainer part numbers??
#37
Thanks for posting the photo xviper.
I think I have posted this before but here goes again:
I have data to show that the S2000 engine will live at redline. The problem is that any more than 9,000 RPM will allow the valves to "float". This means that the cam is turning so fast that the rockers can't stay in contact with the cam lob. As this happens the rocker doesn't push on the valve stem constantly. If the rockers are floating then the valve spring is going to slam the valve closed as hard as it can since the contour of the cam lobe isn't gently closing the valve. (9,000 crank revs per minute is 150 per second/2 or 75 valve slamming per second). With the valve spring at full force closing the valve the only thing stopping the valve is the valve seat but the spring is still working (pushing the retainer up) and the only thing stopping the retainer is the keeper and the valve. Thus the retainer starts to split when the valve isn't controlled by the cam.
When the engine goes more than 10,700 RPM the valves stay open long enough to get slapped by the piston. That is when you see the valve bend and then break off. If the valve only is bent a little it may bend back each time the valve spring is pulling on it and it may close properly and not cause a misfire code. Eventually it will fail and cause extensive damage. That is why someone can say "I was driving slow down a city street and it just failed". That is usually a true statement.
HTH,
woodwork
HTH,
woodwork
Alloyicon19 (06-10-2017)
#40
Good points have been made here. Questions that still remain are:
-Are the 04 retainers stronger, and dimensionally compatible to consider an upgrade...
-Only one out of 16 valve retainers failed, one other APPEARS to have started to fail. Why just this one...
WOODWORK....Major thanks for your contributions here. What do you think of this as a cure for future models....A simple electromechanical device incorporated in to the slave cylinder, controlled by the ecu...It could disengage the clutch at, lets say, 100-200 rpm's higher than the engines preset rev limiter, thus preventing mechanical over-revs.
Just a little info on Woodwork's pic...What were looking at is the underside of the retainer. The gaps at 9, 12, and 3 o'clock are cracks in the retainer. The next gap in the inner ring appears to be a damaged keeper.
