DIY Compression Testing
Old Feb 1, 2008 | 12:23 PM
AssassinJN's Avatar
Great write up man, this is one of those simple things that everyone should know how to do, but few of us do.
Thanks
Oh and I love the exclamation point.
Turn off the car and remove the four screws holding the spark plug cover!
Old Feb 1, 2008 | 01:25 PM
KnowledgeIsPower's Avatar
it takes a real man to go bear foot when hes working on his car
Old Feb 1, 2008 | 02:38 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by mxt_77,Feb 1 2008, 04:14 PM
you should remove all 4 when doing the test
I agree....but nonetheless, good write-up
Old Feb 1, 2008 | 06:08 PM
J'sS2K's Avatar
What's the compression for our engines, both AP1 and AP2?
Jason
Old Feb 2, 2008 | 02:39 AM
dievoche's Avatar
11.1.to 1 for ap1. you asked for both. but this is all i have to offer. may some one bless you with the knowledge i could not provide
Old Feb 2, 2008 | 05:47 PM
jyeung528's Avatar
he's not asking for compression ratio...
rather, in psi.
Old Feb 2, 2008 | 05:50 PM
fadiss2k's Avatar
Edited it so it says to remove all 4 plugs!
Thanks guys!
Old Feb 6, 2008 | 06:09 AM
mxt_77's Avatar
Good info, but why is this sticky'd? Shouldn't it just be linked from one of the FAQs or DIY stickies?
Old Feb 17, 2008 | 10:40 PM
2159ClassicRed's Avatar
Great write up, as I've always wondered how to crank the car, now I do
I'll have to give this a try this weekend.
Old Feb 18, 2008 | 12:49 AM
lethals2000's Avatar
you mention about disableing the fuel system but you didn't mention about disableing the ignition system unless you are disableing it when you remove the clip that is on the coil. i was told to step and hold onto the gas pedal while cranking the engine over when you begin and you should only give it four puffs to see reading or does it not matter.
