DIY Compression Testing
Old Aug 2, 2010 | 07:45 AM
  #61
Gernby's Avatar
Former Sponsor
Originally Posted by ECU Pirate,Aug 2 2010, 10:39 AM
Wow. I just did a compression test and got:
1: 265psi
2: 295psi
3: 270psi
4: 265psi
Any explanation for such high numbers? Did it cold. Just replaced engine with an 05 with 22k miles.
Are you doing the test 2000 feet below sea level?
Old Aug 2, 2010 | 08:16 AM
  #62
ECU Pirate's Avatar
No. I'm at 15ft above sea level. Near the coast of NC
Old Aug 2, 2010 | 08:28 AM
  #63
Gernby's Avatar
Former Sponsor
That was actually a joke, since there probably isn't any place on the planet that would be so far below sea level.
I wouldn't be concerned about it reading high, but I might consider trying a different tester, and also trying it with a warm engine to see how it changes. How many miles on on it?
Old Aug 2, 2010 | 08:39 AM
  #64
ECU Pirate's Avatar
It has 22k according to the company I bought it from. It runs great, I just wanted to test it since it was from a wrecked car and all. I will test again after driving it a little bit
Old Aug 2, 2010 | 09:04 AM
  #65
OneSilverS2k's Avatar
Though I posted that 228 PSI~ was the nominal compression by definition nominal means - . minimal in comparison with real worth or what is expected; token a nominal fee -
So I take this as if you are at 228 that s fine, but I would like to actually find out straight out of the factory what you're suppose to be making, or maybe like after 5,000 miles. I am sure it is different because rings have not seated in the beginning. What do you guys think?
Old Aug 20, 2010 | 05:43 PM
  #66
teamvalorracing's Avatar
this is a helpful thread for those who may not have known how to do a test. accurate to the last bit.
i just did my compression test and here is the breakdown:
F22C 2004 50k miles
fresh oem Honda HG, ARP head studs
5-6 cranks, wide open throttle, operating temp
cyl1: 240-242
cyl2: 240-242
cyl3: 240-242
cyl4: 240-242
keep posting your info guys. this will come in handy for someone some day.
Old Mar 3, 2011 | 01:31 PM
  #67
unbreak_s2k07's Avatar
I can't see any of these pictures? whats going on
Old Jun 17, 2011 | 07:08 PM
  #68
lilsharky's Avatar
just got mine done. sure wished i had someone crank it for me.
cyl 1: 215-220
cyl 2: 200-210
cyl 3: 200-215
cyl 4: 210-215
are these any good? is it a hint that i need a valve adjustment? oh and cyl 3 spark plug had very light oil on it. whats wrong?
Old Jun 17, 2011 | 09:00 PM
  #69
robrob's Avatar
Here's my compression and leak down test how-to: http://robrobinette.com/S2000Compression.htm
Old Apr 4, 2012 | 03:51 AM
  #70
.ben's Avatar
Awesome information here. I would have never thought it would be this straight forward.
