DIY: Hardtop Installation
Has anyone else taken this into consideration?-- If you know you'll be adding a HT eventually, be sure to do it before the soft-top goes bad. This maintains some usefulness of the SF and also maintains extra value at trade-in or resell.
How many people would spend the money required to do both? I don't think many.
hey i had a question about the sub wire harness u think u could send me the part number to it... i been haveing trouble to just find that... i have a jdm s2000 and mines is a 01 ... i been strugglein on find shit for it and tryin to get ahold of stuff but yea if u could maybe pm me or email me bak at dragonflyer228@yahoo.com
great post.. and just to add my 2 cents..
the spacers in the beginning that u put on the soft top, is to cushion the soft top frame. the hardtop rests on the soft top, putting alot of weight on it. so the rubber spacer prevents the frame from touching when the soft top is folded.
second, when using the punch to bend the area for the side latches.
keep the 12mm and 10mm screws in there while hammering away. i took them out first and when i bent it, the screw holes and thread no longer aligned, and i had to go back and bend it to alignment.
thanks for the post and pixs.. deff helped more than the blk and white instructions that honda has.
Originally Posted by littlerocket777,Aug 4 2006, 06:30 AM
Do you happen to have the part number for those 2 rubber spacers that you attached to the soft top? I bought my hardtop used and I obviously don't have those parts. I wonder what they are for, but I'm betting some sort of protection. I'd like to get a pair of those rubber spacers if possible. Thanks!
