DIY: Shift Lite Installation 101
Old Feb 6, 2004 | 09:13 PM
swtazn97's Avatar
Materials:
- #5340 Autometer Pro Shift Lite
- #5369 Autometer 8600RPM pill kit (Includes 5 pill in increments of 200)
- #3250 Autometer Blue Lens Kit (optional)
- Heavy duty Mounting Tape or Industrial Velcro. (Hobby store. I.e.: Michael
Old Feb 6, 2004 | 09:14 PM
swtazn97's Avatar
Step 5: Left side kick panel locate the set of black wires octopuses onto one bolt. See pic.
- Simply T-Tap your black wire here! Lightly pinch with pliers.
Step 6: Tape the green wire on a straight coat hanger and snake it through the rubber gormet under the steering column. See pics.
- This would be a good time to pop your hood,
- The hanger should come out from inside cabin, through the firewall under your hood.
swtazn97's Avatar
Step 7: Locate the Tachometer Test Connector Plug. See pic.
- It
Old Feb 6, 2004 | 11:14 PM
Slows2k's Avatar
I've got the small light mounted in my a-pillar. It's pretty simple to install, good write up. The Big Pro-Lite will BLIND you if you do not use the cover at night, especially if it is directly in your line of sight.
Old Feb 7, 2004 | 01:27 PM
Road Rage's Avatar
Thanks!
But I cannot view the pics. ???
Old Feb 7, 2004 | 02:15 PM
Johnny--2K's Avatar
neither can i...what is the part# for the smaller one, and what does it look like?
Old Feb 7, 2004 | 02:32 PM
Slows2k's Avatar
Here's a pic of the Pro-Lite, It's on the upper left corner of the bottom gauge in the pod.
Old Feb 7, 2004 | 02:49 PM
swtazn97's Avatar
It works if you let the page load up. and right mouse click the picture and select Show Pic.
It was working awhile ago. Lately, my imagestation been having problems. I'll tri to fix it
Old Feb 8, 2004 | 12:32 AM
ExOdy's Avatar
Looks very nice to me. I'm not a fan of those huge ones.
Old Feb 8, 2004 | 04:33 PM
swtazn97's Avatar
Pictures updated! finally it works.
