DIY: Spring and Shock Installation
Old Oct 14, 2011 | 09:13 PM
  #71
MBHs2k's Avatar
This is one of the best DIY I have ever seen. Used this step by step today to install my espelirs!!
Old Oct 14, 2011 | 09:16 PM
  #72
S2Hey's Avatar
What is the cardboard part used for? with the lines?
Old Oct 14, 2011 | 09:52 PM
  #73
spets's Avatar
The tophat bolts are installed at an angle to the lower bushing when looking from the top down. The box with lines is used to help make sure the angle is the same so that you can re-install the suspension more easily.
Old Oct 14, 2011 | 10:02 PM
  #74
S2Hey's Avatar
ok even if i'm just using the oem shock with eibach springs is that necessary?
Old Oct 15, 2011 | 06:58 PM
  #75
S2Hey's Avatar
i have a 4 finger gap right now on the fronts... did i do something wrong or will it all settle out.
Old Oct 30, 2011 | 03:32 PM
  #76
dangthamang's Avatar
are the torque specs the same for ap2 as ap1?
Old Nov 1, 2011 | 10:13 AM
  #77
rjones's Avatar
Yes, with stock springs at stock ride height it should be around 2 finger gap. Did you preload the supension before tightening up the bolts?
Old Nov 2, 2011 | 01:10 PM
  #78
S2Hey's Avatar
thanks for the response, i got it fixed! had to preload >.<
Old Nov 6, 2011 | 12:20 PM
  #79
Nexion's Avatar
Hey man thanks for the DIY, used it today to install new springs!
Old Apr 9, 2012 | 07:06 AM
  #80
Ayge's Avatar
Is there a reason why I can't drill out the rose bushings instead of dremeling them? I measure the piston diameter @ .480", seems like it would be easier to open them up with a 1/2" drill bit. Is the .020" difference in diameter too much play?
