Do I need to replace these pulleys?
Old Jan 9, 2016 | 09:42 AM
solitarycheese's Avatar
Default Do I need to replace these pulleys?
https://www.youtube.com/watch?v=2DDwVcrVv-w
There's a little play in the belt tensioner pulley. The bigger pulley beneath it (water pump?) is solid, but has an audible squeak when the engine was warm. I tried it again this morning (cold) and it was silent.
Old Jan 9, 2016 | 10:25 AM
zeroptzero's Avatar
The tensioner pulley and the idler pulley will both have some play in them as they have bearings, I would say that is not excessive.
The squeak is from the pump as the pulley doesn't have a bearing, not sure what to say about that, if it isn't leaking from the weeper and it turns smoothly it might be fine for a while. Is it noisy when the engine is running ?
Old Jan 11, 2016 | 06:36 AM
No sound when the engine is running. I also spun it again with the engine cold and it didn't make a squeak.
Old Jan 11, 2016 | 12:00 PM
zeroptzero's Avatar
if it doesn't leak and it isn't noisy I'd leave it for now, it will surely let you know when it needs replacing IMO.
E4RTH WORM JIM
Sep 8, 2017 11:34 AM
Mexs2k
Mar 13, 2015 05:34 AM
OMCMT
Apr 10, 2014 10:11 AM
MB
Dec 21, 2005 05:47 AM
rocketman
May 18, 2002 07:41 PM
