Do You Use a Puller on the Water Pump Pulley to Remove it ?
Old Apr 29, 2012 | 05:11 PM
zeroptzero's Avatar
Default Do You Use a Puller on the Water Pump Pulley to Remove it ?
I pulled out the three bolts on the water pump pulley thinking it might come off, but it is on there pretty tight. Do you need to use a puller on the pulley for removal, I'm hesitant to tap on the pulley if you need to use a puller. Thanks for any replies.
Old Apr 29, 2012 | 05:14 PM
Slows2k's Avatar
No puller is needed. Bump it with a rubber hammer.
Old Apr 29, 2012 | 05:21 PM
zeroptzero's Avatar
ah okay I'll try that, it is on there really tight, must be slightly rusted in place, thanks for the reply
Old Apr 29, 2012 | 06:10 PM
zeroptzero's Avatar
I gave it a few good taps with a rubber hammer and it loosened up, thanks for the tip Slows2k.
rcasiano
Jan 11, 2016 09:10 AM
99SH
Apr 16, 2013 09:48 PM
DvS-
Feb 6, 2011 10:00 PM
s2khondas
Feb 22, 2008 08:28 PM
QUICK_AG
Mar 30, 2006 02:43 AM
