Dome light switch not working. Lights work
My dome light switch to change off, always on, or on when doors are open is not working.
When I push the buttons in for each light they work so obviously not the bulbs but the switch is not working. Is that something that can be easily fixed or would I just need to order a new dome let fixture thing?
Started going out a few months ago but would still work if I wiggled the switch around a little but now completely stopped working all together.
Take it apart and see if you can fix it. If you can see the contacts maybe they just need cleaning. If not then you will have to get a new one. They sell for about $70 new online. See link below. The other option would be from a used parts dealer(junk yard).
http://www.hondaautomotiveparts.com/auto/j...=INTERIOR+LIGHT
Originally Posted by S2k_MoZo,Oct 22 2009, 03:21 PM
You might want to use that contact cleaner thing on there, it might be just some carbon buildup inside. I have some if you want to drop by. We can do it at my place.
Thanks guys for the quick responses!
Pop the light cover off.
Remove the two gold screws on each side of the fixture.
There are two small clips at the front of the light to pop off, then the light fixture comes down.
Remove the electrical connector
Take the fixture inside and remove the two gold screws holding the white thing down.
This is what mine looked like. It kinda worked when it wanted to.
Remove the slide switch but BE CAREFUL, it's easy to lose the little ball bearing detent balls.
I cleaned mine up with a brass brush in my Dremel at the lowest speed.
Works great now.
Works great now.
